- To:
- Subject: Re: [cgal-discuss] Bezier curve control points iterator access
- Date: Mon, 11 Feb 2013 15:45:23 +0200
You can rest assure.
The documentation for the type and pair of functions is merely missing and will be added.On Sat, Feb 9, 2013 at 10:14 AM, Shriramana Sharma <> wrote:
Hello.
Arr_Bezier_curve_traits_2<RatKernel,AlgKernel,NtTraits>::Curve_2 has
public members: type Control_point_iterator, control_points_begin()
and control_points_end() defined on lines 327, 432 and 440 of
include/CGAL/Arr_geometry_traits/Bezier_curve_2.h (of CGAL 4.1).
However the documentation of the class at
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2_ref/Class_Arr_Bezier_curve_traits_2.html
does not list the type Control_point_iterator or the corresponding
begin() and end() functions. Given, though, that these are public
members of that class, and given the obvious advantage in being able
to use an iterator, I hope we can rest assured that these are indeed
part of the official API though they are not documented in the manual?
Thanks.
Shriramana Sharma
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
- [cgal-discuss] Bezier curve control points iterator access, Shriramana Sharma, 02/09/2013
- Re: [cgal-discuss] Bezier curve control points iterator access, Efi Fogel, 02/11/2013
