cgal-discuss - Re: [cgal-discuss] Original coordinates translation
  • To:
  • Subject: Re: [cgal-discuss] Original coordinates translation
  • Date: Tue, 12 Feb 2013 09:20:16 +0100
This is a bit obscure, could you tell us more?
Do you mean that the whole object get translated or that
the points are not exactly where you expected them to be?
Note that is you are using a Polyhedral_mesh_domain_3, the points
of the polyhedron are not in general in the final mesh (its surface
get remeshed).
Sebastien.
On 02/11/2013 03:29 PM, Andra wrote:
Hi all,
I am trying to mesh together multiple subdomains using
*mesh_3D_variable_size.*, but the final results have different coordinates
than the original files. Any idea why? Which is the solution to keep the
original coordinates?
Thank you.
Regards,
Andra
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Original-coordinates-translation-tp4656714.html
