- To: nmitchell <>
- Cc:
- Subject: Re: [cgal-discuss] Strange error when linking against CGAL_ImageIO
- Date: Sat, 16 Feb 2013 02:18:16 +0100
nmitchell
writes:
> Hello,
> Trying to diagnosis a strange error I've been getting. I've been
> attempting to add some functionality to the CGAL python bindings, but
> CGAL_ImageIO.so is giving me trouble. Any time I attempt to execute
> anything that is linked against it, I get the following error:
> [nmitchel@cauchy] (796)$ ./a.out
> ./a.out: symbol lookup error: /scratch/SOFTWARE/lib/libCGAL_ImageIO.so.9:
> undefined symbol:
> I've tried with both CGAL 4.1 and 4.0.2, exact same results. It leads
> me to suspect that I may have something wrong with my system, but I
> can't for the life of me determine what is causing the undefined
> symbol message, especially which symbol it is complaining about. If I
> knew, I probably could fix it.
> For reference, here is the test program
> int main(int argc, char** argv)
> return 0;
> and the compile command I used.
> g++ test.cpp -L/scratch/SOFTWARE/lib -lCGAL_ImageIO
Somehow the formatted parts of your message got lost and are only
visible on nabble. I added them in my reply.
I cannot reproduce this with either the ImageIO built by myself or the
one built by my distribution package. How do you compile CGAL?
- [cgal-discuss] Strange error when linking against CGAL_ImageIO, nmitchell, 02/15/2013
- Re: [cgal-discuss] Strange error when linking against CGAL_ImageIO, Philipp Moeller, 02/16/2013
- Re: [cgal-discuss] Strange error when linking against CGAL_ImageIO, Laurent Rineau (CGAL/GeometryFactory), 02/18/2013
