- To: "" <>
- Subject: RE: [cgal-discuss] Help with conversion of Polyhedron 3 to Nef Polyhedron 3.
- Date: Sun, 17 Feb 2013 17:13:33 +0000
- Accept-language: en-GB, en-US
Hi,
try to replace
CGAL::Polyhedron_3<NefKernel,CGAL::Polyhedron_items_with_id_3 >
PolyhedralSurface;
with
CGAL::Polyhedron_3<NefKernel,CGAL:: Polyhedron_items_3 > PolyhedralSurface;
I think you cannot (yet) convert polyhedra with extended item traits into nef
polyhedral.
Cheers
Chris
-----Original Message-----
[mailto:]
On Behalf Of trblair
Sent: 17 February 2013 02:18
To:
Subject: [cgal-discuss] Help with conversion of Polyhedron 3 to Nef
Polyhedron 3.
Hi, I'm try to use the interface between Polyhedron 3 and Nef Polyhedron 3
but I'm getting an error that says the method doesn't exist. Here is the
code I'm using, pretty much right out of the examples, followed by the build
error. Am I missing something in the PolyhedralSurface typedef? Thanks in
advance.
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Gmpz.h>
#include <CGAL/Homogeneous.h>
#include <CGAL/Polyhedron_incremental_builder_3.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/Polyhedron_items_with_id_3.h>
#include <CGAL/Nef_polyhedron_3.h>
typedef CGAL::Homogeneous<CGAL::Gmpz> NefKernel; typedef
PolyhedralSurface; typedef CGAL::Nef_polyhedron_3<NefKernel> Nef_polyhedron;
Nef_polyhedron nefA;
Nef_polyhedron nefB;
std::string CGAL_Boolean_Subtraction(BASE_GEOMETRY geometryA, BASE_GEOMETRY
geometryB){
PolyhedralSurface polyA = buildPolyhedron(geometryA);
PolyhedralSurface polyB = buildPolyhedron(geometryB);
if(polyA.is_closed()){
nefA(polyA);
if(polyB.is_closed()){
nefB(polyB);
nefA -= nefB;
Build error:
CGAL_Boolean_Opperations.cpp: In function ‘std::string
CGAL_Boolean_Subtraction(BASE_GEOMETRY, BASE_GEOMETRY)’:
CGAL_Boolean_Opperations.cpp:18:19: error: no match for call to
‘(Nef_polyhedron {aka CGAL::Nef_polyhedron_3<CGAL::Homogeneous<CGAL::Gmpz>
>}) (PolyhedralSurface&)’
CGAL_Boolean_Opperations.cpp:21:19: error: no match for call to
make[2]: *** [build/Debug/GNU-Linux-x86/CGAL_Boolean_Opperations.o] Error 1
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Help-with-conversion-of-Polyhedron-3-to-Nef-Polyhedron-3-tp4656744.html
- [cgal-discuss] Help with conversion of Polyhedron 3 to Nef Polyhedron 3., trblair, 02/17/2013
- RE: [cgal-discuss] Help with conversion of Polyhedron 3 to Nef Polyhedron 3., Chris Theis, 02/17/2013
