cgal-discuss - RE: [cgal-discuss] Polyhedron validity and closure
  • To: "" <>
  • Subject: RE: [cgal-discuss] Polyhedron validity and closure
  • Date: Wed, 20 Feb 2013 10:59:48 +0000
  • Accept-language: en-GB, en-US
Thanks a lot! That's a very helpful hint.
Cheers
Chris
-----Original Message-----
[mailto:]
On Behalf Of Sebastien Loriot (GeometryFactory)
Sent: 20 February 2013 11:54
To:
Subject: Re: [cgal-discuss] Polyhedron validity and closure
make_triangle creates 3 new vertices each time, even if a vertex with the
same point exists.
The same goes for the incremental builder, each time you call add_vertex, a
new vertex is created. You need a side data-structure to check if you already
created a given vertex and get its index.
If you can't make everything in one builder call, you'll need to look at the
indexing mode documented here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_incremental_builder_3.html
Sebastien.
On 02/20/2013 11:47 AM, Chris Theis wrote:
> Hello,
> I've been trying to do some boolean ops on polyhedra and encountered a
> number of spurious asserts which I could trace back to problems in my
> polyhedron definition. However, I can't really see the problem and
> maybe there is some fundamental misunderstanding on my side.
> I'm trying to create for example a simple triangulated box. For this
> purpose I have written a builder function:
> void operator()( HDS& HalfEdgeDS ) {
> CGAL::Polyhedron_incremental_builder_3<HDS> BuilderObj(
> HalfEdgeDS, true);
> assert( !(m_Vertices.size() % 3) ); // m_Vertices = vector keeping
> all vertices of the polyhedron
> for( size_t i = 0; i< m_Vertices.size(); i += 3 ) {
> BuilderObj.begin_surface( 3, 1 );
> BuilderObj.add_vertex( Point( m_Vertices[i].X,
> m_Vertices[i].Y, m_Vertices[i].Z ) );
> BuilderObj.add_vertex( Point( m_Vertices[i+1].X,
> m_Vertices[i+1].Y, m_Vertices[i+1].Z ) );
> BuilderObj.add_vertex( Point( m_Vertices[i+2].X,
> m_Vertices[i+2].Y, m_Vertices[i+2].Z ) );
> BuilderObj.begin_facet();
> BuilderObj.add_vertex_to_facet( 0 );
> BuilderObj.add_vertex_to_facet( 1 );
> BuilderObj.add_vertex_to_facet( 2 );
> BuilderObj.end_facet();
> BuilderObj.end_surface();
> When I then create a box I can export it to an OFF file and view it
> without any problem. However, if I call the is_valid() function I'm
> told that my structure is not valid. It contains 72 half-edges (I
> would have expected 6 faces * 2 triangles = 36 half-edges) and every
> second HE is reported as a border half edge. Consequently, the solid
> does not classify as closed and boolean ops with nef-polyhedra fail.
> As a test I tried to build the solid with the make_triangle function
> like
> this:
> Poly.make_triangle( CGPoint( 0.0, 0.0, 0.0 ), CGPoint( 0.0, 1.0,
> 0.0 ), CGPoint( 1.0, 0.0, 0.0 ) );
> Poly.make_triangle( CGPoint( 1.0, 0.0, 0.0 ), CGPoint( 0.0, 1.0,
> 0.0 ), CGPoint( 1.0, 1.0, 0.0 ) );
> Poly.make_triangle( CGPoint( 0.0, 0.0, 0.0 ), CGPoint( 1.0, 0.0,
> 0.0 ), CGPoint( 0.0, 0.0, 1.0 ) );
> Poly.make_triangle( CGPoint( 0.0, 0.0, 1.0 ), CGPoint( 1.0, 0.0,
> 0.0 ), CGPoint( 1.0, 0.0, 1.0 ) );
> Poly.make_triangle( CGPoint( 0.0, 0.0, 0.0 ), CGPoint( 0.0, 0.0,
> 1.0 ), CGPoint( 0.0, 1.0, 0.0 ) );
> Poly.make_triangle( CGPoint( 0.0, 1.0, 0.0 ), CGPoint( 0.0, 0.0,
> 1.0 ), CGPoint( 0.0, 1.0, 1.0 ) );
> Poly.make_triangle( CGPoint( 0.0, 1.0, 1.0 ), CGPoint( 1.0, 0.0,
> 1.0 ), CGPoint( 1.0, 1.0, 1.0 ) );
> Poly.make_triangle( CGPoint( 1.0, 0.0, 0.0 ), CGPoint( 1.0, 1.0,
> Poly.make_triangle( CGPoint( 1.0, 0.0, 1.0 ), CGPoint( 1.0, 1.0,
> 0.0 ), CGPoint( 1.0, 1.0, 1.0 ) );
> Poly.make_triangle( CGPoint( 0.0, 1.0, 0.0 ), CGPoint( 0.0, 1.0,
> 1.0 ), CGPoint( 1.0, 1.0, 0.0 ) );
> Poly.make_triangle( CGPoint( 1.0, 1.0, 0.0 ), CGPoint( 0.0, 1.0,
> However, the result was exactly the same.
> I would appreciate if somebody could shed some light on this issue
> because I do not really understand where the border half-edges come
> from. In my current understanding border half edges are adjacent to
> holes and thus, have no face connected to them. However, I do not have
> any holes in my polyhedron or do I?
> Thanks a lot
> Chris
> View this message in context:
> http://cgal-discuss.949826.n4.nabble.com/Polyhedron-validity-and-closu
> re-tp4656773.html Sent from the cgal-discuss mailing list archive at
> Nabble.com.
