- To:
- Subject: Re: Re: [cgal-discuss] Splitting a mesh into different (2) regions
- Date: Tue, 5 Mar 2013 20:18:32 +0100 (CET)
Hi ,
I have a similar issue now albeit slightly different :
I used "refine_Delaunay_mesh_2" to create a mesh.
I have a mesh and I partition this mesh "vertices" into some number of
components (~=3). Now, I need to segment this mesh into this many number of
components, and I need to preserve the triangles (faces) i.e. I do not want to
re-mesh. Is there any simple way to do this ? If I refine mesh by removing
vertices, it might not preserve the previous vertices and also I do not need
to create any vertices.
Post below if you need more informations, etc.
Ratnesh
- Re: Re: [cgal-discuss] Splitting a mesh into different (2) regions, ratneshkumar21, 03/05/2013
