- To:
- Subject: Re: [cgal-discuss] [Arrangement_2] Hiding X-Monotone Curve Cut ?
- Date: Sat, 9 Mar 2013 18:11:20 +0200
Look at the Arrangement_with_history_2 data structure. It maintains a cross mapping between the curves of the arrangement and the curves that induce them.
On Fri, Mar 8, 2013 at 12:25 PM, Tapadi <> wrote:
Hello all,
I am a PhD student at Inria Grenoble, currently working on a geometry design
project using arrangement structures. I am replacing my own incomplete
arrangement implementation by CGAL's one.
I need to keep memory of the largest non-intersecting parts of non
x-monotone curves. I know that computing x-monotone cuts is necessary for
the arrangement's computation, but I would like to hide these cuts in my
final result.
I searched in the forum archives for a similar problem, and I am currently
reading "CGAL Arrangements and Their Applications" for any hint. As far as I
know, the only solution is extending the DCEL, associating the same id to
the edges composing a single inserted curve and traversing the arrangement
ignoring degree-2 vertices whose incident edges share the same id.
... But is there any easier solution ? Thanks in advance for any help !
Best regards,
Hugo Loi
PhD student at Inria - Maverick Team
http://maverick.inria.fr/
PS : Here are the CGAL configuration I use.
Kernel : CGAL::Exact_predicates_inexact_constructions_kernel
Traits : CGAL::Arr_polyline_traits_2<CGAL::Arr_segment_traits_2<Kernel> >
Arrangement : CGAL::Arrangement_2<Traits>
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Arrangement-2-Hiding-X-Monotone-Curve-Cut-tp4656856.html
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
- [cgal-discuss] [Arrangement_2] Hiding X-Monotone Curve Cut ?, Tapadi, 03/08/2013
- Re: [cgal-discuss] [Arrangement_2] Hiding X-Monotone Curve Cut ?, Sebastien Loriot (GeometryFactory), 03/09/2013
- [cgal-discuss] Re: [Arrangement_2] Hiding X-Monotone Curve Cut ?, Tapadi, 03/09/2013
- Re: [cgal-discuss] [Arrangement_2] Hiding X-Monotone Curve Cut ?, Efi Fogel, 03/09/2013
- Re: [cgal-discuss] Re: [Arrangement_2] Hiding X-Monotone Curve Cut ?, Efi Fogel, 03/09/2013
