cgal-discuss - Re: [cgal-discuss] Re: Conics Arrangement : Orientation
  • To:
  • Subject: Re: [cgal-discuss] Re: Conics Arrangement : Orientation
  • Date: Sat, 9 Mar 2013 18:48:59 +0200
The parabolic arc from (-4,2) to (-1,1) is CW. If you choose CCW, you get the complement, which is divided at (0,0) into x-monotone arcs.
On Tue, Mar 5, 2013 at 2:44 PM, Myirci <> wrote:
Hi again,
No one has any idea?
Have a nice week
Murat
On Thu, Feb 28, 2013 at 10:25 AM, Myirci <> wrote:
Hello,
I'm using conics arrangement and I've a difficulty to understand the orientation of the conics arcs. In the simple example below, I want to insert the parabola segment: { y² + x = 0, source (-4,-2), target(-1,1) } in to my arrangement. And according to my understanding, from source point to target, the direction must be CCW. However, in this case, the resultant arrangement has 3 vertices and 2 edges (which is unexpected for me). If I change the orientation to CW then, I get the expected output. Could you clarify my confusion?
Output when orientation is CCW:
3 vertices:
(-4 -2) - degree 1
(0 0) - degree 2
(-1 1) - degree 1
2 edges:
[{0*x^2 + -1*y^2 + 0*xy + -1*x + 0*y + 0} : (-4,-2) --ccw--> (0,0)]
[{0*x^2 + -1*y^2 + 0*xy + -1*x + 0*y + 0} : (0,0) --ccw--> (-1,1)]
Output when orientation is CW:
2 vertices:
(-4 -2) - degree 1
(-1 1) - degree 1
1 edges:
[{0*x^2 + 1*y^2 + 0*xy + 1*x + 0*y + 0} : (-4,-2) --cw--> (-1,1)]
Here is the code:
#include <CGAL/Cartesian.h>
#include <CGAL/CORE_algebraic_number_traits.h>
#include <CGAL/Exact_predicates_exact_constructions_kernel_with_sqrt.h>
#include <CGAL/Segment_Delaunay_graph_2.h>
#include <CGAL/Segment_Delaunay_graph_traits_2.h>
#include <CGAL/Arr_conic_traits_2.h>
#include <CGAL/Arrangement_2.h>
#include "print_arrangement.hpp" // same as the arr_print.h
typedef CGAL::CORE_algebraic_number_traits  Nt_traits;
typedef Nt_traits::Rational                 Rational;
typedef Nt_traits::Algebraic                Algebraic;
typedef CGAL::Cartesian<Rational>           Rat_kernel;
typedef CGAL::Cartesian<Algebraic>          Alg_kernel;
typedef CGAL::Arr_conic_traits_2<
    Rat_kernel, Alg_kernel, Nt_traits>      Traits_2;
typedef Traits_2::Point_2                   Point_2;
typedef Traits_2::Curve_2                   Conic_arc_2;
typedef CGAL::Arrangement_2<Traits_2>       Arrangement_2;
int main() {
    Arrangement_2 conics_arr;
    Conic_arc_2 parabola_arc(0, 1, 0, 1, 0, 0, CGAL::COUNTERCLOCKWISE,
                              Point_2(-4, -2), Point_2(-1, 1));
    if(parabola_arc.is_valid()) {
        CGAL::insert(conics_arr, parabola_arc);
        print_arrangement(conics_arr);
    else { std::cerr << "Conic arc is not valid! " << std::endl; }
    return 0;
Murat Yirci
Murat Yirci
   ____  _        ____             _
  /_____/_) o    /__________  __  //
 (____ (   (    (    (_/ (_/-(-'_(/
                         _/
