cgal-discuss - Re: [cgal-discuss] Re: Compilation errors in Poisson reconstruction sample code(CGAL 4.2 beta1)
  • To:
  • Subject: Re: [cgal-discuss] Re: Compilation errors in Poisson reconstruction sample code(CGAL 4.2 beta1)
  • Date: Thu, 14 Mar 2013 08:30:39 +0100
On 03/14/2013 07:11 AM, Pranav wrote:
Hi,
Problem got solved by adding
*#define CGAL_EIGEN3_ENABLED*
We actually fixed a bug in the code that was expecting a default solver
to be available. Default solver is now available only if
CGAL_EIGEN3_ENABLED is defined.
I am not sure why it was not enabled during Cmake process?
It is if you use the following.
find_package(Eigen3 3.1.0) #(requires 3.1.0 or greater)
if (EIGEN3_FOUND)
include( ${EIGEN3_USE_FILE} )
endif()
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Compilation-errors-in-Poisson-reconstruction-sample-code-CGAL-4-2-beta1-tp4656940p4656950.html
