- To:
- Subject: Re: [cgal-discuss] Hole vertices to CGAL::bounded_side_2
- Date: Fri, 15 Mar 2013 07:05:30 +0100
I don't know what you refers to but an option is to use the following example:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Subsection_37.8.2
And use the locate function of the triangulation to check is it is
inside a face of the domain.
Sebastien.
On 03/01/2013 12:33 PM, Feanoreal wrote:
Hello everyone.
I need to check if point lands in polygon with holes, but i can't figured
out how i can get first and last vertices of holes to paste in fuction
CGAL::ON_UNBOUNDED_SIDE . symmR.front().holes_begin() ,
symmR.front().holes_end() not working.
CGAL::bounded_side_2 ( intR.front().outer_boundary().vertices_begin() ,
intR.front().outer_boundary().vertices_end() , point_to_check, Kernel()) -
working.
CGAL::bounded_side_2(symmR.front().holes_begin() , symmR.front().holes_end()
, point_to_check, Kernel()) - not working.
How can i paste<ForwardIterator first> and<ForwardIterator last> of symmR
hole to this function?
Thank you very much!
Andrey.
P.S. previous topic have been rejected, so i create a new - hope i doesn't
doublepost it. And sorry for possible mistakes.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Hole-vertices-to-CGAL-bounded-side-2-tp4656810.html
- [cgal-discuss] Hole vertices to CGAL::bounded_side_2, Feanoreal, 03/01/2013
- Re: [cgal-discuss] Hole vertices to CGAL::bounded_side_2, Sebastien Loriot (GeometryFactory), 03/15/2013
