- To:
- Subject: Re: [cgal-discuss] Clarification regarding cgal CT and CDT iterators :
- Date: Mon, 25 Mar 2013 06:58:39 +0100
You should use the one from CT. It is working because the iterator are
taken from CT which is a the base class of CDT.
Sebastien.
On 03/23/2013 06:52 PM,
wrote:
I have defined Constrained Delaunay Triangulation (CDT) before in my code,
and now due to some reasons I have to use Constrained Triangulations (CT).
However I accidently did not change the iterators type. For example my face
iterator was - typedef CDT::Finite_faces_iterator finite_face_iterator; and I
used it same for CT.
I use it the same for all other iterators and circulators. I did not face any
issues yet , but I just want to make sure that I am not doing something wrong
conceptually ?
Thanks
R
- [cgal-discuss] Clarification regarding cgal CT and CDT iterators :, ratneshkumar21, 03/23/2013
- Re: [cgal-discuss] Clarification regarding cgal CT and CDT iterators :, Sebastien Loriot (GeometryFactory), 03/25/2013
