- To:
- Subject: Re: [cgal-discuss] Convex_hull_3 -> points.size() > 3
- Date: Mon, 25 Mar 2013 11:13:51 +0100
You are using the overload filling a polyhedron that expects to have at
least three non-collinear points provided as input.
The solution is to either check on your side this, or use the global
function returning an object.
Sebastien.
On 03/25/2013 11:04 AM, mastair wrote:
I am calculating a lot of convex_hull_3, and somewhere along the way I get
this error:
CGAL error: precondition violation!
Expression : points.size()> 3
File : c:\dev\cgal-4.1\include\cgal\convex_hull_3.h
Line : 880
Any suggestion of what the problem might be?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Convex-hull-3-points-size-3-tp4657015.html
- [cgal-discuss] Convex_hull_3 -> points.size() > 3, mastair, 03/25/2013
- Re: [cgal-discuss] Convex_hull_3 -> points.size() > 3, Sebastien Loriot (GeometryFactory), 03/25/2013
- Re: [cgal-discuss] Convex_hull_3 -> points.size() > 3, Roeland Boeters, 03/25/2013
