- To:
- Subject: [cgal-discuss] Re: .off To .stl coverter
- Date: Fri, 29 Mar 2013 04:11:26 -0700 (PDT)
Hi richard,
really thanks for your code but i've an error i do not know why.
i used your code in my function that is the same as in Surface
reconstruction points example
(http://doc.cgal.org/4.2/CGAL.CGAL.Surface-Reconstruction-from-Point-Sets/html/Surface_reconstruction_points_3_2poisson_reconstruction_example_8cpp-example.html):
CGAL::make_surface_mesh(c2t3, // reconstructed mesh
surface, // implicit surface
criteria, // meshing criteria
CGAL::Manifold_with_boundary_tag()); // require
manifold mesh
ExportLumenSTLSolid(c2t3,"prova.stl");
i commented what i don'need in ExportLumen in this way:
template<class T>
void ExportLumenSTLSolid(const T& surf, const std::string& filename/*,
std::vector< endCapStruct > *caps=NULL*/)
using namespace std;
typedef typename T::Facet_iterator Facet_iterator;
typedef typename T::Cell_handle Cell_handle;
typedef typename T::Vertex_handle Vertex_handle;
typedef EK::Point_3 EP;
/* vector<endCapStruct>::iterator cIter;*/
IK_to_EK to_exact;
EK_to_IK to_inexact;
ofstream stlFile(filename.c_str());
stlFile << "solid FUSSOLID stereolithography representation of
angio/ivus fusion results" << endl;
Facet_iterator f = surf.facets_begin();
for( ; f != surf.facets_end(); f++) {
Cell_handle cHnd = f->first;
Vertex_handle h[3];
h[0] = ( f->second==0 ? cHnd->vertex( 1 ) : cHnd->vertex( 0 ) );
h[1] = ( f->second < 2 ? cHnd->vertex( 2 ) : cHnd->vertex( 1 )
h[2] = ( f->second < 3 ? cHnd->vertex( 3 ) : cHnd->vertex( 2 )
bool render = true;
bool out_of_bounds[3];
EP eP[3];
for (int i=0; i<3; i++) {
eP[i] = to_exact(h[i]->point());
out_of_bounds[i] = false;
/* if (caps) {
for (cIter = caps->begin(); cIter != caps->end(); cIter++) {
CGAL::Vector_3<EK> tmpVec = eP[i] - CGAL::ORIGIN;
EP transposed = CGAL::ORIGIN +
tmpVec.transform(cIter->bbTransform);
if
((cIter->plane.oriented_side(eP[i])!=CGAL::ON_POSITIVE_SIDE) &&
(cIter->bb.bounded_side(transposed)==CGAL::ON_BOUNDED_SIDE)) {
EP tmp = cIter->plane.projection(eP[i]);
eP[i] = tmp;
out_of_bounds[i] = true;
render = (!(out_of_bounds[0] && out_of_bounds[1] &&
out_of_bounds[2]));
/* if (render) {*/
CGAL::Vector_3<IK> n = CGAL::normal( to_inexact(eP[0]),
to_inexact(eP[1]), to_inexact(eP[2]) );
stlFile << " facet normal " << n.x() << " " << n.y() << " "
<< n.z() << endl;
stlFile << " outer loop" << endl;
stlFile << " vertex " << eP[i].x() << " " <<
eP[i].y() << " " << eP[i].z() << endl;
stlFile << " endloop" << endl;
stlFile << " endfacet" << endl;
stlFile << "endsolid FUSSOLID" << endl;
stlFile.close();
but i don't know why i ave a mismatch error:
error C2664: 'std::pair<_Ty1,_Ty2>
CGAL::Cartesian_converter<K1,K2>::operator ()(const
std::pair<CGAL::Point_2<R_>,CGAL::Point_2<R_>> &) const' : cannot convert
parameter 1 from 'CGAL::Point_3<R_>' to 'const std::pair<_Ty1,_Ty2> &'
this happen in the line
" eP[i] = to_exact(h[i]->point());"
my include files are these:
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Quotient.h>
#include <CGAL/MP_Float.h>
#include <CGAL/Cartesian_converter.h>
typedef CGAL::Simple_cartesian<double> IK;
typedef CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> > EK;
typedef CGAL::Cartesian_converter<IK,EK> IK_to_EK;
typedef CGAL::Cartesian_converter<EK,IK> EK_to_IK;
Do you have any suggestion??
Mario
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/off-To-stl-coverter-tp4657020p4657075.html
- [cgal-discuss] .off To .stl coverter, mario, 03/25/2013
- Re: [cgal-discuss] .off To .stl coverter, Tomislav Maric, 03/25/2013
- [cgal-discuss] Re: .off To .stl coverter, mario, 03/25/2013
- Re: [cgal-discuss] Re: .off To .stl coverter, Richard Downe, 03/26/2013
- [cgal-discuss] Re: .off To .stl coverter, mario, 03/29/2013
- Re: [cgal-discuss] Re: .off To .stl coverter, Richard Downe, 03/29/2013
