- To:
- Subject: [cgal-discuss] Fwd: ** April 2013 issue of IEEE T-ASE available
- Date: Sun, 7 Apr 2013 10:57:59 +0300
Dear All,
I'm forwarding a message from Prof. Ken Goldberg, the Editor in Chief of the T-ASE journal.Best,
Efi---------- Forwarded message ----------
Date: Sat, Apr 6, 2013 at 3:32 AM
Subject: ** April 2013 issue of IEEE T-ASE available
To: T-ASE Editorial Board <>
Cc: Faith Agnew T-ASE EiC Office <>, Ken Goldberg - T-ASE EiC <>
Dear All, IEEE had an Xplore snafu that delayed this a week; I'll send it out to mailing lists on Sunday...Thanks to Faith and all for your hard work on this! Please enjoy and forward to colleagues and students...
Best,
Ken
As noted in the Table of Contents below, the April 2013 issue of the
IEEE Transactions on Automation Science and Engineering (T-ASE)
features a Guest Editorial by Vijay Kumar and SK Gupta on Exciting
Trends in Manufacturing, new results from Efi Fogel and Danny Halperin
on the open-source Computational Geometry Algorithms Library (CGAL)
which offers guarantees of correctness, and papers on innovative
topics such as using mobile phones as seismologic sensors, new sensors
and actuators for micro- and nano-scale automation, and applications
in steelmaking, trains, and power generation:
http://ieeexplore.ieee.org/xpl/tocresult.jsp?isnumber=6493467&punumber=8856
This links to the Table of Contents, which allows free access to
Editorials, Abstracts of all papers, and to the full text of "Open
Access" papers (via the .pdf links).
Details on T-ASE, info for authors, and upcoming Special Issues on our
newly re-designed website:
http://www.ieee-ras.org/publications/t-ase
The IEEE Conference on Automation Science and Engineering deadline for
"Presentation Only" 2-page Abstracts (intended primarily for
non-academics) is May 1: http://www.case2013.org/
Table of Contents
GUEST EDITORIAL
Exciting Trends for Automation in Manufacturing
Gupta, S.K. ; Kumar, V.
REGULAR PAPERS
Polyhedral Assembly Partitioning With Infinite Translations or The Importance of
Being Exact
Fogel, E. ; Halperin, D.
Mobile Phones as Seismologic Sensors: Automating Data Extraction for the iShake
System
Reilly, J. ; Dashti, S. ; Ervasti, M. ; Bray, J. D. ; Glaser, S. D. ; Bayen, A.
M.
Design, Simulation, and Fabrication of Microneedles and a Blood Filter for Use
in a Hemofiltration System
Tayyaba, S. ; Ashraf, M. W. ; Afzulpurkar, N.
Experimental Analysis of Laser Interferometry-Based Robust Motion Tracking
Control of a Flexure-Based Mechanism
Bhagat, U. ; Shirinzadeh, B. ; Tian, Y. ; Zhang, D.
AFAM: An Articulated Four Axes Microrobot for Nanoscale Applications
Murthy, R. ; Stephanou, H. E. ; Popa, D. O.
AFM-Based Robotic Nano-Hand for Stable Manipulation at Nanoscale
Hou, J. ; Liu, L. ; Wang, Z. ; Wang, Z. ; Xi, N. ; Wang, Y. ; Wu, C. ; Dong, Z.
; Yuan, S.
A Geometric Distribution Reader Anti-Collision Protocol for RFID Dense Reader
Environments
Bueno-Delgado, M. V. ; Ferrero, R. ; Gandino, F. ; Pavon-Marino, P. ;
Rebaudengo, M.
An Effective Artificial Bee Colony Algorithm for a Real-World Hybrid Flowshop
Problem in Steelmaking Process
Pan, Q.-K. ; Wang, L. ; Mao, K. ; Zhao, J.-H. ; Zhang, M.
Coordinated Iterative Learning Control Schemes for Train Trajectory Tracking
With Overspeed Protection
Sun, H. ; Hou, Z. ; Li, D.
Energy Saving Opportunity Analysis of Automotive Serial Production Systems
Chang, Q. ; Xiao, G. ; Biller, S. ; Li, L.
Swarm Intelligence Approaches to Optimal Power Flow Problem With Distributed
Generator Failures in Power Networks
Kang, Q. ; Zhou, M. ; An, J. ; Wu, Q.
Adaptive Dispatching Rule for Semiconductor Wafer Fabrication Facility
Li, L. ; Sun, Z. ; Zhou, M. ; Qiao, F.
Development and Evaluation of Object-Based Visual Attention for Automatic
Perception of Robots
Yu, Y. ; Gu, J. ; Mann, G. K. I. ; Gosine, R. G.
An Integrated Two-Level Self-Calibration Method for a Cable-Driven Humanoid Arm
Chen, Q. ; Chen, W. ; Yang, G. ; Liu, R.
Fault Detection by Labeled Petri Nets in Centralized and Distributed Approaches
Fanti, M. P. ; Mangini, A. M. ; Ukovich, W.
Performance Metrics of Speed and Separation Monitoring in Shared Workspaces
Marvel, J. A.
Hybrid Analysis in the Latent Nestling Method Applied to Fault Diagnosis
Rodriguez Urrego, L. ; Garcia Moreno, E. ; Morant Anglada, F. ; Correcher
Salvador, A. ; Quiles Cucarella, E.
Functional and Behavior Models for the Supervision of an Intelligent and
Autonomous System
Chatti, N. ; Gehin, A.-L. ; Ould-Bouamama, B. ; Merzouki, R.
SHORT PAPERS
Optimal Alarm Signal Processing: Filter Design and Performance Analysis
Cheng, Y. ; Izadi, I. ; Chen, T.
Similarity Analysis of Industrial Alarm Flood Data
Ahmed, K. ; Izadi, I. ; Chen, T. ; Joe, D. ; Burton, T.
Online Sensor Activation for Detectability of Discrete Event Systems
Shu, S. ; Huang, Z. ; Lin, F.
A Semi-Automated Positioning System for Contact-Mode Atomic Force Microscopy
(AFM)
Roy, R. ; Chen, W. ; Cong, L. ; Goodell, L. A. ; Foran, D. J. ; Desai, J. P.
An Assembly-Skill-Transferring Method for Cellular Manufacturing System—Part I:
Verification of the Proposed Method for Motor Skill
Duan, F. ; Gao, Q. ; Zhu, C. ; Kato, R. ; Arai, T.
Self-Configuration of Waypoints for Docking Maneuvers of Flexible Automated
Guided Vehicles
Herrero, D. ; Villagra, J. ; Martinez, H.
Thin Layer SOI-FETs Used for Stress-Sensing and Its Application in
Accelerometers
Wang, H. ; Yang, J. ; Yan, S. ; Jin, Z.
** Early Access articles are made available well in advance of their
appearance in the publication cycle:
http://ieeexplore.ieee.org/xpl/tocresult.jsp?isnumber=4358066
Best,
Ken
Table of Contents
GUEST EDITORIAL
REGULAR PAPERS
Being Exact
System
M.
; Yuan, S.
Environments
Rebaudengo, M.
Marvel, J. A.
Autonomous System
SHORT PAPERS
(AFM)
Guided Vehicles
Accelerometers
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
- [cgal-discuss] Fwd: ** April 2013 issue of IEEE T-ASE available, Efi Fogel, 04/07/2013
