- To:
- Subject: Re: [cgal-discuss] Re: co-planar testing
- Date: Wed, 10 Apr 2013 14:03:04 -0700
I recommend reading this: http://www.cgal.org/philosophy.html
On 4/10/2013 1:56 PM, 刘先勇 wrote: Thanks for your reply, Evan .
I
just used the simple function CGAL::coplanar. It always
tells me that my testing data is non-planar.
Please
reference http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Function_coplanar.html.
Also, I found another post about coplanarity from http://cgal-discuss.949826.n4.nabble.com/concrete-example-of-coplanar-points-td4312826.html.
Therefore, I am quite confused. If the Jacobian value is
very near to 0, we say they are coplanar. The Jacobian value
of the given data above is -8.48237e-008, but what's the
standard to set a reasonable threshold?
Hopefully, somebody could share their experience if they
met the same problem before.
Xianyong Liu.
2013/4/10 Evan Behar <>
I just used the following function to have a coplanar
testing, found that it returns me false.
I'm
sorry, I didn't see where you specified the function
you used to do the coplanar test.
On Wed, Apr 10, 2013 at 3:24
PM, ayongwust_sjtu <>
wrote:
This is the right testing data: v1 [0] = -0.22209167480468750 [1] = 0.50670331716537476 [2] = 1.0210649967193604 v2 [1] = 0.45931974053382874 [2] = 0.95057666301727295 v3 [0] = 0.41287946701049805 [1] = 0.37877112627029419 [2] = -1.0771968364715576 v4 [0] = -0.40214806795120239 [1] = 0.42615470290184021 [2] = -1.0067086219787598 ----- ------------- Regards, Xianyong Liu -- Sent from the cgal-discuss mailing list
archive at Nabble.com.
-- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://sympa.inria.fr/sympa/info/cgal-discuss |
- [cgal-discuss] co-planar testing, 刘先勇, 04/10/2013
- [cgal-discuss] Re: co-planar testing, ayongwust_sjtu, 04/10/2013
- Re: [cgal-discuss] Re: co-planar testing, Evan Behar, 04/10/2013
- Re: [cgal-discuss] Re: co-planar testing, 刘先勇, 04/10/2013
- Re: [cgal-discuss] Re: co-planar testing, Cody Rose, 04/10/2013
- Re: [cgal-discuss] Re: co-planar testing, Sebastien Loriot (GeometryFactory), 04/10/2013
- Re: [cgal-discuss] Re: co-planar testing, 刘先勇, 04/11/2013
- Re: [cgal-discuss] Re: co-planar testing, Olivier Devillers, 04/11/2013
