- To:
- Subject: Re: [cgal-discuss] About the adding the Compiler optimization
- Date: Thu, 11 Apr 2013 16:53:09 +0200
When using cmake, you can do (if the cache is clean)
cmake -DCMAKE_BUILD_TYPE=Release .
If you use this option when building the lib CGAL, simply choosing the
correct
build of CGAL will switch this on.
See also
http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_installation_manual.html#Section_14
Sebastien.
On 04/11/2013 03:24 PM, arno wrote:
> Hello everyone:
> I am a stranger to the makefile, could anyone tell me how to add the
> compiler optimization when compiling the example in
> 'CGAL-4.1/examples/', and what is the default compiler optimization
> flag(O1,O2 or O3)? I am using the g++-4.7, ubuntu 12.10. Thanks a lot!
> Chunhui Zhang---Xidian University from China.
- [cgal-discuss] About the adding the Compiler optimization, arno, 04/11/2013
- Re: [cgal-discuss] About the adding the Compiler optimization, Sebastien Loriot (GeometryFactory), 04/11/2013
- Re: Re: [cgal-discuss] About the adding the Compiler optimization, Laurent Rineau (CGAL/GeometryFactory), 04/11/2013
