cgal-discuss - Re: [cgal-discuss] CGAL 4.2 Released, Computational Geometry Algorithms Library
  • To:
  • Subject: Re: [cgal-discuss] CGAL 4.2 Released, Computational Geometry Algorithms Library
  • Date: Sun, 14 Apr 2013 19:21:38 +0200
Hi,
On 04/11/2013 03:52 PM, Laurent Rineau (CGAL/GeometryFactory) wrote:
> The CGAL Open Source Project is pleased to announce the release 4.2
> of CGAL, the Computational Geometry Algorithms Library.
Debian packages for CGAL 4.2 are now available as well. Simply add
deb ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian squeeze main
deb-src ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian squeeze main
deb ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian wheezy main
deb-src ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian wheezy main
to /etc/apt/sources list (you only need the pair of lines corresponding
to the release you are using). For experimental, packages should be
available from the official Debian repository in a few days. The
packages are called libcgal10, libcgal-dev, libcgal-qt4-10,
libcgal-qt4-dev, libcgal-demo, and libcgal-ipelets.
In case you want to download the packages manually, have a look at
ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian/pool/main/c/cgal/
See also http://www.cgal.org/FAQ.html#debian_packages .
Joachim
