- To:
- Subject: Re: [cgal-discuss] Re: OS X installation of 4.2
- Date: Mon, 22 Apr 2013 12:10:11 +0200
Le samedi 20 avril 2013 13:59:32 David Bernstein a écrit :
> Seems like the problem here is in the "+demos" part. Is there someone I can
> contact who would be able to look at the macports files and maybe try to
> track this down?
I think you should contact the macports developers, through their mailing
list
or bug tracker. CGAL developers cannot know how macports tries to compile the
CGAL library. In the error you quote in your first mail, they even explain
how
to report a bug to macports:
> Error: org.macports.build for port cgal returned: command execution failed
> Please see the log file for port cgal for details:
/opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/
cgal/main.log
> To report a bug, follow the instructions in the guide:
> http://guide.macports.org/#project.tickets
> Error: Processing of port cgal failed
Laurent Rineau, PhD
- [cgal-discuss] OS X installation of 4.2, Bernstein, 04/19/2013
- [cgal-discuss] Re: OS X installation of 4.2, David Bernstein, 04/20/2013
- Re: [cgal-discuss] Re: OS X installation of 4.2, Laurent Rineau (CGAL/GeometryFactory), 04/22/2013
- [cgal-discuss] Re: OS X installation of 4.2, David Bernstein, 04/22/2013
