- To:
- Subject: [cgal-discuss] Circle-Circle-intersection
- Date: Tue, 23 Apr 2013 14:58:56 +0800
Dear list,
As part of a (for this mailing list not that interesting) algorhtm, I have to determine whether two circles intersect. I do this using CGAL::do_intersect(...) as described on http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Function_do_intersect.html
Now I believe that there either is a bug in the implementation, or in the documentation, as my interpretation of the latter does not correspond to the behaviour of the former. The documentation states that:
for objects like triangles and polygons that enclose a bounded region, this region is part of the object.
This led me to believe that for circles, which also enclose a bounded region, this would also apply. I therefore assumed that when one circle is embedded in the other (i.e. their boundaries do not intersect), CGAL::do_intersect(...) would return true. After all, the bounded regions do intersect. However, CGAL behaves differently, and performs the intersection test on the boundary alone. I have attached a test program that shows this behaviour.
Tested on CGAL 4.1, Windows 8 64-bit, Visual Studio 2010.
I fully understand that a circle is not a disc, and that the behaviour of CGAL::do_intersect is perfectly defendable. However, a change in the documentation may be a good idea. It would have saved me a few days of debugging my code.
Kind regards,
#include <CGAL/Point_2.h> #include <CGAL/Circle_2.h> #include <CGAL/Cartesian.h> #include <iostream> typedef CGAL::Cartesian<double> K; typedef CGAL::Circle_2<K> Circle_2; typedef CGAL::Point_2<K> Point_2; int main(void) { Circle_2 inner(Point_2(0, 0), 1); Circle_2 outer(Point_2(0, 0), 4); if (CGAL::do_intersect(inner, outer)) { std::cout << "Circles intersect" << std::endl; } else { std::cout << "Circles do not intersect" << std::endl; } return 0; }
- [cgal-discuss] Circle-Circle-intersection, Sybren A . Stüvel, 04/23/2013
- Re: [cgal-discuss] Circle-Circle-intersection, Monique Teillaud, 04/24/2013
- Re: [cgal-discuss] Circle-Circle-intersection, Sybren A . Stüvel, 04/24/2013
