- To:
- Subject: Re: [cgal-discuss] Converting FT to double in Extended_cartesian with Gmpq
- Date: Sat, 27 Apr 2013 18:32:07 -0400
Ah, wonderful! Thank you very much!
On Sat, Apr 27, 2013 at 6:26 PM, Marc Glisse <> wrote:
On Sat, 27 Apr 2013, Evan Behar wrote:
Better use CGAL::to_double instead of hoping for a member function.Ah, thanks. I also forgot to ask the other part of the question, though this
helps me get to the point:
I want to convert values in my Point_3 to doubles (for rendering, output,
etc.), but when I write
p.x().exact().to_double()
or
p.x().to_double() I get the error:
Apparently not, seems to be some undocumented polynomial type (look at CGAL/Nef_polynomial.h if you need details about that type).
Is FT not Lazy_exact_nt< CGAL::Gmpq >?
Marc Glisse
- [cgal-discuss] Converting FT to double in Extended_cartesian with Gmpq, Evan Behar, 04/27/2013
- Re: [cgal-discuss] Converting FT to double in Extended_cartesian with Gmpq, Marc Glisse, 04/27/2013
- Re: [cgal-discuss] Converting FT to double in Extended_cartesian with Gmpq, Evan Behar, 04/28/2013
- Re: [cgal-discuss] Converting FT to double in Extended_cartesian with Gmpq, Marc Glisse, 04/28/2013
- [cgal-discuss] Trouble with instalation of CGAL, Eliseu Castelo Branco Jr, 04/28/2013
- Re: [cgal-discuss] Trouble with instalation of CGAL, Marc Glisse, 04/28/2013
