cgal-discuss - [cgal-discuss] range_search in delaunay triangulation
  • To:
  • Subject: [cgal-discuss] range_search in delaunay triangulation
  • Date: Tue, 07 May 2013 14:12:20 +0200
I just tried to add a range search function to my ruby interface code of
cgals constrained delaunay triangulation
(http://www.ssalewski.de/CDT.html.en).
Seems to work, as long as there are no constraints inserted prior to
calling range search. Is this restriction intended -- or I am doing
something wrong?
With constrains, I get this message:
range search 8,8, 3
terminate called after throwing an instance of
'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Expr: ! are_there_incident_constraints(v)
File: /usr/include/CGAL/Constrained_Delaunay_triangulation_2.h
I guess that is not a big problem for me, I should be able to do all
searching prior to inserting constraints.
Does this restriction apply to nearest neighbor search also?
One more question -- I found this
http://cgal-discuss.949826.n4.nabble.com/range-search-problem-td953126.html
Sep 21, 2009; 2:32pm
>when I tried to call range_search, the delaunay mesh changes!(some edge
>flippling
Is it true, that range search can modify the triangulation structure?
Best regards,
Stefan Salewski
  • [cgal-discuss] range_search in delaunay triangulation, Stefan Salewski, 05/07/2013
