- To: <>
- Subject: Re: [cgal-discuss] Bug report: Polytope_distance_d package
- Date: Fri, 10 May 2013 09:44:33 +0200
Dear Jérémie,
thanks for reporting this. I think I know where the problem is (the underlying quadratic programming solver cycles). For now, I cannot offer any fix, except the one you suggest: since cycling is a very instable phenomenon, it usually goes away when you change the input order. Of course, we will look into a general fix.
All the best,
Bernd.
On 5/9/13 12:07 AM, jdumas wrote:
Hi.
I think I've put a finger on an unexpected behavior in the package
Polytope_distance_d. It happens when the second polygon is reduced to a
single point, and only with certain coordinates. The issue is that the
solver simply hangs indefinitely instead of computing the right answer. The
interesting thing is that if I switch P and Q then the solver find the
optimal solution immediatly.
Here is a link to the minimal example code (adapted from the examples
shipped with CGAL):
http://pastebin.com/viCkT8Xw
My version of CGAL is 4.2, and gcc is 4.7.2.
Best,
Jérémie.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-report-Polytope-distance-d-package-tp4657397.html
- [cgal-discuss] Bug report: Polytope_distance_d package, jdumas, 05/09/2013
- Re: [cgal-discuss] Bug report: Polytope_distance_d package, Bernd Gärtner, 05/10/2013
