- To:
- Subject: [cgal-discuss] Surface Meshing with congruent fixed ratio triangles
- Date: Sun, 12 May 2013 03:48:40 -0700 (PDT)
Hi CGAL guys,
I want to mesh a surface with congruent isoscele triangles with a given
aspect ratio (see [1]). Am I the first one who tries to accomplish this in
CGAL? Until now I tried defining my own criterion for make_surface_mesh
marking a facet as bad if the deviation from the aspect ratio is more than a
certain treshold. But it seems like the algorithm either does not terminate
or I have to raise the treshhold to a value where it's not useful anymore...
Have any advice on that problem?
Cheers
Jakob
[1]
http://stackoverflow.com/questions/13577516/tiling-approximating-a-3d-surface-with-identical-polygons
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Surface-Meshing-with-congruent-fixed-ratio-triangles-tp4657410.html
- [cgal-discuss] Surface Meshing with congruent fixed ratio triangles, javra, 05/12/2013
- [cgal-discuss] Re: Surface Meshing with congruent fixed ratio triangles, javra, 05/26/2013
