- To:
- Subject: Re: [cgal-discuss] Problem to write/read nef file
- Date: Thu, 16 May 2013 12:02:07 +0200
On 05/16/2013 11:56 AM, Guillaume Caron wrote:
Ok, thank you for the answer but as I said I have the same problem withNo, it is something like Lazy_kernel< Simple_cartesian< CGAL::Gmpq >, ... > for which a specialization is available.
the predefined kernel CGAL::Exact_predicates_exact_constructions_kernel.
And if I understood correctly,
CGAL::Exact_predicates_exact_constructions_kernel is equal to:
CGAL::Cartesian<CGAL::Lazy_exact_nt<CGAL::Quotient<CGAL:Gmpz>>>.
Do you still have the problem?
Sebastien.
So if the problem is a specialization of an internal writer missing for
a kernel using Lazy_exact_nt, the predefined kernel can not work either,
no?
Guillaume.
Le 16/05/2013 11:38, Sebastien Loriot (GeometryFactory) a écrit :
There is a specialization of an internal writer missing for a kernel
using Lazy_exact_nt as number type.
If it is OK for you, use
CGAL::Exact_predicates_exact_constructions_kernel as "kernel".
I'll try to fix this for the next release of CGAL.
Sebastien.
On 05/15/2013 03:51 PM, Guillaume C wrote:
Hi,
I'm new to CGAL, and i try to write a Nef_polyhedron in a nef file
and read
it after. But i have an error when i use lazy_exact_nt or predefined
kernels.
My program:
typedef CGAL::Lazy_exact_nt< CGAL::Gmpq> FT_t;
typedef CGAL::Cartesian< FT_t> kernel;
typedef CGAL::Nef_polyhedron_3< kernel> Nef_polyhedron;
typedef CGAL::Polyhedron_3< kernel> Polyhedron;
typedef Polyhedron::Point_3 Point;
int main()
Point p(sqrt(2), 0, 0);
Point q( 0,sqrt(2), 0);
Point r( 0, 0,sqrt(2));
Point s( 0, 0, 0);
Nef_polyhedron Cube,Cube2;
Polyhedron P;
P.make_tetrahedron( p, q, r, s);
Cube=P;
std::ofstream out ("temp.nef");
out<< Cube;
std::ifstream in ("temp.nef");
in>> Cube;
return 0;
And the error:
/terminate called after throwing an instance of
'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
File: /home/ostab/PACKAGE/CGAL-3.9/include/CGAL/Nef_3/SNC_io_parser.h
Line: 1368
Explanation: SNC_io_parser::read: error in node line
Abandon/
Thank you.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-to-write-read-nef-file-tp4657449.html
- [cgal-discuss] Problem to write/read nef file, Guillaume C, 05/15/2013
- [cgal-discuss] Re: Problem to write/read nef file, ChaoM, 05/15/2013
- Re: [cgal-discuss] Problem to write/read nef file, Sebastien Loriot (GeometryFactory), 05/16/2013
- Re: [cgal-discuss] Problem to write/read nef file, Guillaume Caron, 05/16/2013
- Re: [cgal-discuss] Problem to write/read nef file, Guillaume Caron, 05/21/2013
- Re: [cgal-discuss] Problem to write/read nef file, Sebastien Loriot (GeometryFactory), 05/21/2013
- Re: [cgal-discuss] Problem to write/read nef file, Guillaume Caron, 05/22/2013
