- To:
- Subject: [cgal-discuss] Re: Naming convention of compiling libraries
- Date: Fri, 17 May 2013 19:18:13 -0700 (PDT)
Dear Sebastien,
Thanks for your reply. Yes I did.
The previous CGAL version I used is 4.0. The library name generated in debug
mode was CGAL-vc100-mt-gd-4.0.lib. Everything went well. But now when I
compile 4.2, the library name generated in debug mode became *
lib*CGAL-vc100-mt-gd-4.2.lib.
I do not know why the CGAL team made such change. A negative problem is that
vs2010 shows me the compiling error when I reference *
lib*CGAL-vc100-mt-gd-4.2.lib in my application.
LINK : fatal error LNK1104: cannot open file 'CGAL-vc100-mt-gd-4.2.lib'
BTW, the CGAL 4.2 works because the library names are the same with that of
CGAL 4.0.
Regards,
Xianyong Liu
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Naming-convention-of-compiling-libraries-tp4657415p4657490.html
- [cgal-discuss] Naming convention of compiling libraries, ayongwust_sjtu, 05/13/2013
- [cgal-discuss] Re: Naming convention of compiling libraries, ayongwust_sjtu, 05/17/2013
- Re: [cgal-discuss] Re: Naming convention of compiling libraries, Sebastien Loriot (GeometryFactory), 05/17/2013
- [cgal-discuss] Re: Naming convention of compiling libraries, ayongwust_sjtu, 05/18/2013
- Re: [cgal-discuss] Re: Naming convention of compiling libraries, Andreas Fabri, 05/18/2013
