- To:
- Subject: [cgal-discuss] Re: update of power diagram vertices
- Date: Tue, 21 May 2013 09:48:05 -0700 (PDT)
My last question here, hopefully it doesn't bother you. How can I test if a
vertex-handle is valid or not? I couldn't find the doc for vertex_handle and
thus, not sure whether there exists a is_valid() method for a vertex_handle.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/update-of-power-diagram-vertices-tp4657493p4657544.html
- [cgal-discuss] Re: update of power diagram vertices, (continued)
- [cgal-discuss] Re: update of power diagram vertices, liudaisuda, 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/22/2013
- Re: [cgal-discuss] update of power diagram vertices, Haibo Chen, 05/22/2013
- Re: [cgal-discuss] update of power diagram vertices, 杨成林, 05/22/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/20/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Haibo Chen, 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/23/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Olivier Devillers, 05/23/2013
