Re: Re: [cgal-discuss] Re: 3D meshing of multidomain segmented images with sharp features
- To:
- Subject: Re: Re: [cgal-discuss] Re: 3D meshing of multidomain segmented images with sharp features
- Date: Wed, 22 May 2013 12:54:54 -0700 (PDT)
Thanks Laurent, That works and produces a .inr file.
After playing with the code for a while it appears that the problem with the
subdomain_index occurs only when I add 1D features to preserve the image
edges (the 12 edges of the image bounding box). In this case the Polyline_3
objects are lists with only two Points in them. I've checked the lists and
they are indeed all edges of the bounding box.
This might be a problem with my code but if not I'll try to boil it down to
a form I can post to the forum which you can run that replicates the
problem.
Thanks,
Dave
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-meshing-of-multidomain-segmented-images-with-sharp-features-tp4657504p4657561.html
- [cgal-discuss] 3D meshing of multidomain segmented images with sharp features, Jack Lee, 05/20/2013
- [cgal-discuss] Re: 3D meshing of multidomain segmented images with sharp features, David Bernstein, 05/20/2013
- [cgal-discuss] Re: 3D meshing of multidomain segmented images with sharp features, David Bernstein, 05/21/2013
- Re: [cgal-discuss] Re: 3D meshing of multidomain segmented images with sharp features, Andreas Fabri, 05/21/2013
- Re: [cgal-discuss] Re: 3D meshing of multidomain segmented images with sharp features, David Bernstein, 05/21/2013
- Re: [cgal-discuss] Re: 3D meshing of multidomain segmented images with sharp features, David Bernstein, 05/22/2013
- Re: Re: [cgal-discuss] Re: 3D meshing of multidomain segmented images with sharp features, Laurent Rineau (CGAL/GeometryFactory), 05/22/2013
- Re: Re: [cgal-discuss] Re: 3D meshing of multidomain segmented images with sharp features, David Bernstein, 05/22/2013
- Re: [cgal-discuss] 3D meshing of multidomain segmented images with sharp features, Laurent Rineau (CGAL/GeometryFactory), 05/21/2013
- [cgal-discuss] Re: 3D meshing of multidomain segmented images with sharp features, ChaoM, 05/21/2013
- Re: [cgal-discuss] Re: 3D meshing of multidomain segmented images with sharp features, Laurent Rineau (CGAL/GeometryFactory), 05/21/2013
