cgal-discuss - [cgal-discuss] CGAL 4.2 Windows Installer vs. PATH
  • To:
  • Subject: [cgal-discuss] CGAL 4.2 Windows Installer vs. PATH
  • Date: Mon, 27 May 2013 17:09:55 +0200 (CEST)
Hello,
I just encountered a problem with the installer of CGAL 4.2 on Windows 7 x64
concerning the windows environment variable PATH. CGAL Installer replaced PATH
by auxiliary\gmp\lib instead of adding the latter to PATH.
What I did:
I went through installer options and changed Install directory to a different
drive letter (F:\cgal-4.2) and allowed the installer to ADD gmp-lib path to
PATH.
What I noticed:
When setup was completed, some things on my system were very strange: I colud
no longer call some system programs from command line which had been possible
just minutes before. I checked my environment variables and found PATH was set
to:
PATH=F:\CGAL-4.2\auxiliary\gmp\lib
(please note that PATH had been several hundred characters just before,
include C:\Windows\system32 to start with.)
When I uninstalled CGAL, PATH was empty afterwards. It will take me some time
to fix my system... :-(
I'd appreciate if you could check and maybe fix the cgal 4.2 install script.
Best regards
Manfred
P.S.: I found that the installer suggests to use the folder "C:\Program Files
\cgal-4.2" when I choose to install 32-bit libraries. The folder "C:\Program
Files" is meant to host 64-bit applications on x64 versions of windows.
Microsoft suggests the folder "C:\Program Files (x86)" to install 32-bit
applications on a Windows x64 system.
