cgal-discuss - Re: [cgal-discuss] Re: CGAL_Core - Build Failed
  • To:
  • Subject: Re: [cgal-discuss] Re: CGAL_Core - Build Failed
  • Date: Mon, 27 May 2013 10:36:10 -0700
If you install CGAL on windows, I suggest you read http://www.cgal.org/windows_installation.html. It is helpful. My experience told me that you need not change any settings in the CMAKE GUI, and then build CGAL.sln in both release and debug modes.
2013/5/27 שלמה גלר <>
Thanks Andreas
In that case it's odd. When I installed CGAL, I specifically checked "with GMP and MPFR".
Also, in CMAKE I made sure it's checked. so I believe the GMP isn't missing.
Maybe there is another problem?
Shlomo
Isn't just GMP missing? The installer allows to download
precompiled versions  of it.
andreas
On 27/05/2013 11:37, שלמה גלר wrote:
Hi
I have run CGAL.sln, and when it got to build CGAL_Core I got this massage:
error LNK2019: unresolved external symbol __imp____gmpz_init referenced
in function "public: __thiscall CORE::BigIntRep::BigIntRep(void)"
(??0BigIntRep@CORE@@QAE@XZ)
and 45 massages like this right after this one. Which made the build of
CGAL_Core fail.
I looked it up through the net and I got to this discussion:
http://cgal-discuss.949826.n4.nabble.com/Cannot-Build-CGAL-Core-td4655731.html
I did what this discussion offered but I got to the same result.
I will appreciate your help.
Shlomo Geller
2013/5/27 שלמה גלר < <mailto:>>
    Hi
    massage:
    referenced in function "public: __thiscall
    CORE::BigIntRep::BigIntRep(void)" (??0BigIntRep@CORE@@QAE@XZ)
    of CGAL_Core fail.
    <http://cgal-discuss.949826.n4.nabble.com/Cannot-Build-CGAL-Core-td4655731.html>
    Shlomo Geller
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912    skype: andreas.fabri
