- To:
- Subject: [cgal-discuss] Re: Nef_Polyhedron is_simple() going wild
- Date: Mon, 27 May 2013 21:22:44 -0700 (PDT)
HEllo Sebastien :
These are my points of two halfspheres, and the code used for Nef
union!
But the result does not satisfied my request! For the bottom of two
halfspheres should not participate in the triangulation. So I want to know
,is there any solution to fix this problem?
Thank you !
code.txt
<http://cgal-discuss.949826.n4.nabble.com/file/n4657605/code.txt>
Nef_out.off
<http://cgal-discuss.949826.n4.nabble.com/file/n4657605/Nef_out.off>
Nef_out1.off
<http://cgal-discuss.949826.n4.nabble.com/file/n4657605/Nef_out1.off>
out3.off <http://cgal-discuss.949826.n4.nabble.com/file/n4657605/out3.off>
<http://cgal-discuss.949826.n4.nabble.com/file/n4657605/27.bmp>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Nef-Polyhedron-is-simple-going-wild-tp3558754p4657605.html
- [cgal-discuss] Re: Nef_Polyhedron is_simple() going wild, ChaoM, 05/28/2013
- Re: [cgal-discuss] Re: Nef_Polyhedron is_simple() going wild, Sebastien Loriot (GeometryFactory), 05/29/2013
