[cgal-discuss] Re: Perform boolean operation between an open mesh and a closed mesh
- To:
- Subject: [cgal-discuss] Re: Perform boolean operation between an open mesh and a closed mesh
- Date: Sun, 2 Jun 2013 07:00:45 -0700 (PDT)
HEllo:
As far as I consider, the Nef poly should be is_simple! So you should
also see this link:
http://cgal-discuss.949826.n4.nabble.com/Nef-polygon-td4657453.html
Hope help for you ~ And we can comunicate each other~
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Perform-boolean-operation-between-an-open-mesh-and-a-closed-mesh-tp4657631p4657636.html
- [cgal-discuss] Re: Perform boolean operation between an open mesh and a closed mesh, ChaoM, 06/03/2013
