- To:
- Subject: [cgal-discuss] mesh optimization
- Date: Wed, 5 Jun 2013 16:29:28 +0200 (CEST)
Hello,
my question concerns the optimization phase of the 3D mesh generation.
I have an existing tetrahedral mesh and I would like to detect if there are bad quality tetrahedron, and if so fix them.
That is why I would like to maybe use the optimization phase of the 3d mesh generation.
The functions corresponding to the different optimization processes expect a C3T3 as input. I saw that this structure is generated by CGAL::make_mesh_3 or CGAL::refine_mesh_3.
But, I cannot call these function as my mesh is already existing.
Is it possible to use the optimization functions (such as lloyd_optimized_mesh_3 etc) on a an existing mesh? If so, should I create an empty C3T3 structure and fill it with my mesh topology? In that case, what attributes should I fill to use it in the optimization functions? And how to define the MeshDomain_3?
Maybe it's impossible as the optimization process asks data computed in CGAL::make_mesh_3.
Thanks,
Alexandre Bilger
- [cgal-discuss] mesh optimization, Alexandre Bilger, 06/05/2013
