cgal-discuss - Re: [cgal-discuss] QGraphicsView and CGAL::Arangement_2
  • To:
  • Subject: Re: [cgal-discuss] QGraphicsView and CGAL::Arangement_2
  • Date: Tue, 11 Jun 2013 18:46:42 +0300
Thank you, Changwon.
It seems that there were few other problems when compiling the demo with VC 10.
I think that I've fixed them all.
Attached are 4 patches you will need to apply, some of which fixes the problem above. (Apply the first 2 under the arrangement demo directory and the last 2 under include/CGAL.)
I've also committed the fixes, so that they will be reflected in the next public release.
On Tue, Jun 11, 2013 at 6:40 AM, changwon lee <> wrote:
Hello
I met same problem during CGAL 4.2 demo compilation with visual studio 2010.
solution is
in Arrangement_on_surface_with_history_2.h
  typedef Arrangement_on_surface_with_history_2<Geometry_traits_2,
                                                Base_topology_traits>  Self;
  typedef Self OuterSelf;  //define another Self
  class Curve_halfedges : public Curve_2,
                          public In_place_list_base<Curve_halfedges>
    friend class Curve_halfedges_observer;
    friend class Arrangement_on_surface_with_history_2<GeomTraits_, TopTraits_>;
    friend class Arr_with_history_accessor<OuterSelf>;
because Self is also defined in base class Curve_2 (it is private)
regards
On 2013-05-28 오후 11:27, Asher Kamiraze wrote:
Hi all,
The demo compiles fine on linux. However, on Windows, VC2010, I have a compilation error (the same in many files):
2>C:/Program Files/CGAL-4.2/include\CGAL/Arrangement_on_surface_with_history_2.h(185): error C2248: 'CGAL::internal::Filtered_bbox_circular_arc_2_base<CK,Base_CK>::Self' : cannot access private typedef declared in class 'CGAL::internal::Filtered_bbox_circular_arc_2_base<CK,Base_CK>'
2>          with
2>          [
2>              CK=CGAL::Filtered_bbox_circular_kernel_2<CGAL::internal::CK1>,
2>              Base_CK=CGAL::internal::Circular_kernel_base_ref_count<CGAL::Filtered_bbox_circular_kernel_2<CGAL::internal::CK1>,CGAL::Cartesian_base_ref_count<NT,CGAL::Filtered_bbox_circular_kernel_2<CGAL::internal::CK1>>,CGAL::internal::Algebraic_k1>
2>          ]
2>          C:/Program Files/CGAL-4.2/include\CGAL/Circular_kernel_2/Circular_arc_2.h(734) : see declaration of 'CGAL::internal::Filtered_bbox_circular_arc_2_base<CK,Base_CK>::Self'
2>          with
2>          [
2>          ]
2>          C:/Program Files/CGAL-4.2/include\CGAL/Arrangement_on_surface_with_history_2.h(538) : see reference to class template instantiation 'CGAL::Arrangement_on_surface_with_history_2<GeomTraits_,TopTraits_>::Curve_halfedges' being compiled
2>          with
2>          [
2>              GeomTraits_=Arc_traits,
2>              TopTraits_=CGAL::Arr_bounded_planar_topology_traits_2<Arc_traits,Arc_dcel>
2>          ]
2>          C:/Program Files/CGAL-4.2/include\CGAL/Arrangement_with_history_2.h(48) : see reference to class template instantiation 'CGAL::Arrangement_on_surface_with_history_2<GeomTraits_,TopTraits_>' being compiled
2>          with
2>          [
2>          ]
2>          c:\users\asherk\work\dev\cgal_demo\arrangement_on_surface_2\ArrangementTypes.h(276) : see reference to class template instantiation 'CGAL::Arrangement_with_history_2<GeomTraits_,Dcel_>' being compiled
2>          with
2>          [
2>              Dcel_=Arc_dcel
2>          ]
2>  EnvelopeCallback.cpp
I do not clearly see where does the problem come from. Do you have any idea, or already succeeded in compiling this demo on windows with vc2010?
Best regards,
Asher
2013/5/28 Asher Kamiraze <>
Many thanks Laurent, this is exactly what I was looking for!
Regards,
Asher
2013/5/27 Laurent Rineau (CGAL/GeometryFactory) <>
Le samedi 25 mai 2013 10:51:01 Asher Kamiraze a écrit :
> Hi all,
> I am wondering what is the best way to display a CGAL arrangement within
> the Qt grphics view framework. Reading CGAL doc, it seems that only exists
> triangulation and voronoi classes derived from QGraphicsItem.
There must be undocumented code in the Qt4 demo of CGAL arrangements, here:
  demo/Arrangement_on_surface_2
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
   ____  _        ____             _
  /_____/_) o    /__________  __  //
 (____ (   (    (    (_/ (_/-(-'_(/
                         _/
Attachment: ArrangementDemoWindow.patch
Description: Binary data
Attachment: ArrangementGraphicsItem.patch
Attachment: Arrangement_with_history_2.patch
Attachment: Arrangement_on_surface_with_history_2.patch
