[cgal-discuss] capture of errors during conversion of Polyhedron_3 to Nef_polyhedron_3
- To:
- Subject: [cgal-discuss] capture of errors during conversion of Polyhedron_3 to Nef_polyhedron_3
- Date: Tue, 11 Jun 2013 17:15:41 -0700
Hello,
I have run into a repeated problem where I have a Polyhedron_3 such that is_valid() and is_closed() both return true, but conversion to Nef_polyhedron_3 (using the Nef_polyhedron_3 constructor) fails. In Debug builds, an assertion is violated, and in Release builds, my program just crashes. I see in the documentation that this conversion is only possible if the point set is an oriented closed 2-manifold, and the function Polyhedron_3::is_closed() tests this, but this is clearly not the only failure mode, and the fact that any other failure modes that I don't anticipate results in crashes for my users is extremely unfortunate. Is there any way to force CGAL to fail this conversion in a predictable, catchable way even with NDEBUG defined? (Alternatively, is this just a bug? If so I can provide an example polygon that does this.)
Thank you,
Cody Rose
- [cgal-discuss] capture of errors during conversion of Polyhedron_3 to Nef_polyhedron_3, Cody Rose, 06/12/2013
- Re: [cgal-discuss] capture of errors during conversion of Polyhedron_3 to Nef_polyhedron_3, Sebastien Loriot (GeometryFactory), 06/12/2013
