- To: "" <>
- Subject: [cgal-discuss] Construction Nef_polyhedron_3
- Date: Thu, 27 Jun 2013 00:36:22 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Rocket-MIMEInfo:X-Mailer:References:Message-ID:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=zsv3t83qwlMCWNptceC8KkLYImAG7u9efrGl8NX9GlDSC/8857rhSsUSYq1/yB5UX/X8Ah588hh3+KikfDpGqICjX/856ybbvIPAGFQIAeaiSrjCefSClAy4RybjhN4wbPbpquUYlet6qHz8mGqq8S/JOk+LiCtaIwAe/V/e8WU=;
Hi All,
I am trying to use the cgal library but I have a problem in the construction
of the Nef_polyhedron_3 from a polyhedron_3 .
I construct a polyhedron 3 from a sequence of triangle facet and the
polyhedron is 2-manifold, closed , simple , all the faces are constructed in
counterclockwise order.
The code fail in the assertion
CGAL_assertion(pe_prev->is_border() || !
internal::Plane_constructor<Plane>::get_plane(pe_prev->facet(),pe_prev-
>facet()->plane()).is_degenerate());
in the file "polyhedron_3_to_nef_3.h"
I don't understand where is the problem . What this assertion exactly means?
This is the code I use to build the nef_3
template<class HDS>
class Build_GTrimesh : public CGAL::Modifier_base<HDS>
public:
typedef typename HDS::Vertex Vertex;
typedef typename Vertex::Point Point;
Build_GTrimesh (TGTriMesh *_m):M(_m)
void operator()(HDS &hds)
int i,n,ip;
CGAL::Polyhedron_incremental_builder_3<HDS> B(hds,true);
B.begin_surface(M->GetNumPoints(),M->GetNumFaces(),M-
>GetNumEdges()*2);
n=M->GetNumPoints();
for (i=0;i<n;i++)
B.add_vertex(Point((double)M->GetPoint(i)[0],
(double)M->GetPoint(i)[1],(double)M->GetPoint(i)[2]));
n=M->GetNumFaces();
for (i=0;i<n;i++)
B.begin_facet();
for (ip=0;ip<3;ip++)
B.add_vertex_to_facet(M-
>GetFacePointIndex(i,ip));
B.end_facet();
B.end_surface();
TGTriMesh *M;
bool GTriMeshToPolyhedron3(TGTriMesh *m,Polyhedron &P)
bool b1,b2,b3;
if (!m)
return false;
b1=m->Is2Manifold();
b2=m->IsClosed();
b3=m->isDegenerateFace();
Build_GTrimesh<typename Polyhedron::HalfedgeDS> PBuilder(m);
P.delegate(PBuilder);
b1=P.is_valid();
b2=P.is_closed();
Nef_polyhedron N3(P);
b1=N3.is_simple();
b2=N3.is_valid();
return b1&&b2;
I get the error executing "GTriMeshToPolyhedron3" in the constructor of the
Nef_polyhedron and all previous check are positive .
Thank you for the help.
Denis.
template<class HDS>
public:
int i,n,ip;
>GetNumEdges()*2);
for (i=0;i<n;i++)
n=M->GetNumFaces();
for (i=0;i<n;i++)
B.begin_facet();
B.end_facet();
B.end_surface();
TGTriMesh *M;
bool b1,b2,b3;
if (!m)
return false;
b2=m->IsClosed();
b1=P.is_valid();
b2=P.is_closed();
b1=N3.is_simple();
b2=N3.is_valid();
return b1&&b2;
Denis.
- [cgal-discuss] Construction Nef_polyhedron_3, Denis Denis, 06/27/2013
