- To:
- Subject: Re: [cgal-discuss] mesh optimization
- Date: Tue, 02 Jul 2013 09:45:45 +0200
On 06/05/2013 04:29 PM, Alexandre Bilger wrote:
Hello,This is only possible if your input mesh fits into a c3t3, that is it can fit in a 3D regular triangulation.
my question concerns the optimization phase of the 3D mesh generation.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_3/Chapter_main.html
I have an existing tetrahedral mesh and I would like to detect if there
are bad quality tetrahedron, and if so fix them.
That is why I would like to maybe use the optimization phase of the 3d
mesh generation.
The functions corresponding to the different optimization processes
expect a C3T3 as input. I saw that this structure is generated by
CGAL::make_mesh_3 or CGAL::refine_mesh_3.
But, I cannot call these function as my mesh is already existing.
Is it possible to use the optimization functions (such as
lloyd_optimized_mesh_3 etc) on a an existing mesh? If so, should I
create an empty C3T3 structure and fill it with my mesh topology? In
that case, what attributes should I fill to use it in the optimization
functions? And how to define the MeshDomain_3?
Maybe it's impossible as the optimizationprocess asks data computed in
CGAL::make_mesh_3.
Sebastien.
Thanks,
Alexandre Bilger
- Re: [cgal-discuss] mesh optimization, Sebastien Loriot (GeometryFactory), 07/02/2013
