- To:
- Subject: Re: [cgal-discuss] add 3rd-party flags to cgal example
- Date: Wed, 03 Jul 2013 09:00:30 +0200
You can add in your cmake script:
find_library(OpenGL)
Then you can use the following variables:
# OPENGL_FOUND - system has OpenGL
# OPENGL_XMESA_FOUND - system has XMESA
# OPENGL_GLU_FOUND - system has GLU
# OPENGL_INCLUDE_DIR - the GL include directory
# OPENGL_LIBRARIES - Link these to use OpenGL and GLU
On my system FindOpenGL.cmake is in /usr/share/cmake-2.8/Modules
Have you seen this CGAL package:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/GraphicsView/Chapter_main.html
It should help you write a small demo.
Sebastien.
On 07/02/2013 04:45 PM, Raul Gallegos wrote:
Hello,
I am creating an example on CGAL and my code is GL/gl.h and GL/glut.h
libraries, to draw some simple points with opengl.
I want to add the corresponding flags (-lgl -lglu -lglut) to the
compilation of my program but I don't understand make or cmake commands
so I don't know where to put them.
I copied the cgal_create_CMakeLists script to my folder, then run it,
and it created a CMakeLists.txt file, then I run it with cmake . and
finally it gives me the Makefile, which I use to compile my code just
running make.
Thank you.
Raul O. Gallegos Hidalgo
- [cgal-discuss] add 3rd-party flags to cgal example, Raul Gallegos, 07/02/2013
- Re: [cgal-discuss] add 3rd-party flags to cgal example, Sebastien Loriot (GeometryFactory), 07/03/2013
