cgal-discuss - Re: [cgal-discuss] BOOST_FOREACH.
  • To:
  • Subject: Re: [cgal-discuss] BOOST_FOREACH.
  • Date: Thu, 4 Jul 2013 18:22:31 -0700
Some work has been done, for example Triangulation_data_structure_3 has .vertices() (resp. .cells()) returning Vertex_range (resp. Cell_range).  But it did not get extended to the Triangulation_3 level yet, apparently.  Besides BOOST_FOREACH, the new for loop in C++11 would also benefit from this.
2013/7/4 Nico Kruithof <>
Yes, but that still is more typing. I was hoping that there were CGAL functions for that would do that for me. I'll just stick with the normal for loop. It's just syntactical sugar.
Nico
On Thu, Jul 4, 2013 at 6:16 PM, Cody Rose <> wrote:
You could probably use a boost iterator range as an adaptor: http://www.boost.org/doc/libs/1_54_0/libs/range/doc/html/range/reference/utilities/iterator_range.html
Cody
On 7/4/2013 7:53 AM, Nico Kruithof wrote:
Hi,
I like BOOST_FOREACH but as I far as know, it needs a container and not a range. What would be the most convenient way to use it with the vertices of a triangulation where you only have the ..._begin() and ..._end() members?
Nico Kruithof
Nico Kruithof
