- To:
- Subject: Re: [cgal-discuss] RE: get the Tetrahedrons of a delaunay triangulation
- Date: Thu, 18 Jul 2013 17:58:38 +0200
Try:
Vertex_handle v;
v->info();
Sebastien.
On 07/18/2013 05:52 PM, zoli0726 wrote:
Thank you, im much closer to this.
Now my vertices have indicies, i can query them, but the output of the
triangulation, or the tetrahedron() gives the same result, no sign of
indicies. The tetrahedron() method know which vertices belongs to the
cell, but is there any way, that i can query them for the info i wrote
into them?
So what i want in the last step, iterate through the cells (I can do
that), and write not(or not only) the coordinates of the vertices of the
cells, just the info of the vertices, or both.
Date: Thu, 18 Jul 2013 08:04:24 -0700
From: [hidden email] </user/SendEmail.jtp?type=node&node=4657813&i=0>
To: [hidden email] </user/SendEmail.jtp?type=node&node=4657813&i=1>
Subject: Re: get the Tetrahedrons of a delaunay triangulation
Vertices do not have index by default,
if you want some, you have to put these indices
see
http://doc.cgal.org/4.2/CGAL.CGAL.3D-Triangulations/html/index.html
Sections 5.5 to 5.8
If you reply to this email, your message will be added to the discussion
below:
http://cgal-discuss.949826.n4.nabble.com/get-the-Tetrahedrons-of-a-delaunay-triangulation-tp4657808p4657812.html
To unsubscribe from get the Tetrahedrons of a delaunay triangulation,
click here.
NAML
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble:email.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble:email.naml-instant_emails%21nabble:email.naml-send_instant_email%21nabble:email.naml>
View this message in context: RE: get the Tetrahedrons of a delaunay
triangulation
<http://cgal-discuss.949826.n4.nabble.com/get-the-Tetrahedrons-of-a-delaunay-triangulation-tp4657808p4657813.html>
Sent from the cgal-discuss mailing list archive
<http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
- [cgal-discuss] get the Tetrahedrons of a delaunay triangulation, zoli0726, 07/18/2013
- Re: [cgal-discuss] get the Tetrahedrons of a delaunay triangulation, Olivier Devillers, 07/18/2013
- [cgal-discuss] RE: get the Tetrahedrons of a delaunay triangulation, zoli0726, 07/18/2013
- [cgal-discuss] Re: get the Tetrahedrons of a delaunay triangulation, zoli0726, 07/18/2013
- Re: [cgal-discuss] Re: get the Tetrahedrons of a delaunay triangulation, Olivier Devillers, 07/18/2013
- Re: [cgal-discuss] RE: get the Tetrahedrons of a delaunay triangulation, Sebastien Loriot (GeometryFactory), 07/18/2013
