RE: [cgal-discuss] would like to understand how the facet and cell size objectives, and node insertion, work in Mesh_3
- To: "" <>
- Subject: RE: [cgal-discuss] would like to understand how the facet and cell size objectives, and node insertion, work in Mesh_3
- Date: Tue, 23 Jul 2013 17:08:46 +0000
- Accept-language: en-US
Hi Mariette,
thanks for your kind support. Your description explains a lot of concepts on which I had questions.
Warm wishes,
Michel
Michel Audette, Ph.D.
Assistant Professor,
Department of Modeling, Simulation and Visualization Engineering,
Old Dominion University,
Norfolk, VA.
Sent: Tuesday, July 23, 2013 5:08 AM To: Subject: Re: [cgal-discuss] would like to understand how the facet and cell size objectives, and node insertion, work in Mesh_3 edge_size bounds the size of edge which are part of 1 dimensional sharp feature approximation fecet_size bounds the radius of the surface Delaunay sphere of surface facet ( surface facets have by definition an empty circumsphere centered on the surface) cell_size bounds the circumradius of any tet in the mesh The Mesh_3 package of CGAL is based on Delaunay refinement and therefore can't guarantee to preserve the discretization of the input surface even if this surface mesh satisfies the meshing criteria. Indeed, input surface meshes might not have the Delaunay property. On one hand, this is a drawback of our meshing algorithm. On the other hand, since Mesh_3 is able to provide in a single meshing process multi-component domain mesh, respecting all boundaries and subdividing surface patches, there is generally no more need to preserve the input surface meshes. Simply think that the work performed to generate these input surface meshes is performed at the same time by CGAL meshing packahge Le 22/07/13 19:52, Audette, Michel A. a écrit :
-- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] would like to understand how the facet and cell size objectives, and node insertion, work in Mesh_3, Audette, Michel A., 07/22/2013
- Re: [cgal-discuss] would like to understand how the facet and cell size objectives, and node insertion, work in Mesh_3, Mariette Yvinec, 07/23/2013
- RE: [cgal-discuss] would like to understand how the facet and cell size objectives, and node insertion, work in Mesh_3, Audette, Michel A., 07/23/2013
