cgal-discuss - Re: [cgal-discuss] Finding all the planes/polygons that form the boundaries of a single voronoi 3D cell?
  • To:
  • Subject: Re: [cgal-discuss] Finding all the planes/polygons that form the boundaries of a single voronoi 3D cell?
  • Date: Tue, 23 Jul 2013 19:30:40 +0100
On 23/07/2013 18:28, Sebastien Loriot (GeometryFactory) wrote:
Compute all dual vertices at once by iterating over cells
(use a std map for the association or use
Triangulation_cell_base_with_info_3 [1] to store an index in a
vector, ...).
Then iterate over all edges and turn around the edge ( t.incident_cells(Edge e) ) and get each vertex of the polygon.
Note that in case of infinite cells, you'll have rays to consider.
I advise you to read:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3_ref/Class_Delaunay_triangulation_3.html#Index_anchor_1689
Note that if you need to build a more complicated data structure,
the demo of the package Linear cell complex can build the Voronoi
diagram of a set of points.
Thanks Sebastien. Perfect.
