cgal-discuss - Re: [cgal-discuss] Tag all faces in the Constrained Delaunay triangulation
  • To:
  • Subject: Re: [cgal-discuss] Tag all faces in the Constrained Delaunay triangulation
  • Date: Fri, 02 Aug 2013 07:19:11 +0200
You can use Triangulation_face_base_with_info_2 [1] together with
Constrained_triangulation_face_base_2 [2] to store any info in the
face and do what you want.
Sebastien.
[1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_face_base_with_info_2.html
[2] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Constrained_triangulation_face_base_2.html
On 08/01/2013 08:31 PM, Bear wrote:
Hi,
I have a group of enclosed polygons and use them as constraints to construct
a constrained Delaunay triangulation. I want to locate the polygons which a
triangulation face is belonging to. A face may be inside 0, 1, or several
polygons. These polygons may have holes, overlap, and shared edges.
How can I do?
The Constrained Delaunay Demo shows how to check whether a face is in
domain, but it is not enough for me.
Thanks in advance.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Tag-all-faces-in-the-Constrained-Delaunay-triangulation-tp4657869.html
