- To:
- Subject: Re: [cgal-discuss] problems with valgrind
- Date: Mon, 5 Aug 2013 10:35:13 -0400
Dear CGAL developers, I'm currently experiencing some problems to use CGAL under Valgrind.
The code, using valgrind, terminate showing the message:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: -CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1)
File: /home/avilla/Documenti/CGAL-4.0/releaseStatic/include/CGAL/Interval_nt.h
Line: 160
Explanation: Wrong rounding: did you forget the -frounding-math option if you use GCC (or -fp-model strict for Intel)?
The program has been compiled using the following flags : -frounding-math -pipe -Wall -W -g -O0 -DHAVE_CONFIG_H -fpermissive
The compiler is gcc-4.6.1
Is there any workaround?
Thankyou very much.
Andrea Villa.
RSE SpA ha adottato il Modello Organizzativo ai sensi del D.Lgs.231/2001, in forza del quale l'assunzione di obbligazioni da parte della Società avviene con firma di un procuratore, munito di idonei poteri. RSE adopts a Compliance Programme under the Italian Law (D.Lgs.231/2001). According to this RSE Compliance Programme, any commitment of RSE is taken by the signature of one Representative granted by a proper Power of Attorney.
Le informazioni contenute in questo messaggio di posta elettronica sono riservate e confidenziali e ne e' vietata la diffusione in qualsiasi modo o forma. Qualora Lei non fosse la persona destinataria del presente messaggio, La invitiamo a non diffonderlo e ad eliminarlo, dandone gentilmente comunicazione al mittente. The information included in this e-mail and any attachments are confidential and may also be privileged. If you are not the correct recipient, you are kindly requested to notify the sender immediately, to cancel it and not to disclose the contents to any other person.
- [cgal-discuss] problems with valgrind, Villa Andrea (RSE), 08/05/2013
- Re: [cgal-discuss] problems with valgrind, Panagiotis Foteinos, 08/05/2013
- Re: [cgal-discuss] problems with valgrind, Sebastien Loriot (GeometryFactory), 08/05/2013
