cgal-discuss - Re: [cgal-discuss] Polygon_2 intersection
  • To:
  • Subject: Re: [cgal-discuss] Polygon_2 intersection
  • Date: Wed, 7 Aug 2013 17:22:57 +0300
You need to use CGAL::Exact_predicates_exact_constructions_kernel
   ____  _        ____             _
  /_____/_) o    /__________  __  //
 (____ (   (    (    (_/ (_/-(-'_(/
                         _/
On Wed, Aug 7, 2013 at 5:17 PM, ax487 <> wrote:
Hello all,
I am trying to intersect two Polygon_2's using the CGAL::intersection
subroutine from CGAL/Boolean_set_operations_2.h.
Unfortunately, I get the following error:
terminate called after throwing an instance of
'CGAL::Precondition_exception'
  what():  CGAL ERROR: precondition violation!
Expr: ! _predP->is_valid() || comp_f(object, _predP->object) != SMALLER
File: /usr/include/CGAL/Multiset.h
Line: 2143
The error is deep inside the stack (what does that error message mean
anyways?), I am not at all familiar with the way that CGAL computes the
intersection of polygons (could you give me some literature reference)?
My Polygon_2 instances are:
0.150000000000000, 0.950000000000000
0.096033821847732, 0.896033821847732
0.150000000000000, 0.850000000000000
0.203966178152268, 0.803966178152268
0.250000000000000, 0.850000000000000
0.300000000000000, 0.900000000000000
0.250000000000000, 0.950000000000000
0.200000000000000, 1.000000000000000
and
0.037954613459116, 0.945576109694670
0.200000000000000, 0.800000000000000
I am using the CGAL::Exact_predicates_inexact_constructions_kernel and
CGAL 4.2. Could anyone explain to me what is going on and how I can get
this subroutine to work properly?
ax487
