cgal-discuss - Re: [cgal-discuss] Compiling the ipelets on OS X 10.7.5 with IPE 7.1.4
  • To:
  • Subject: Re: [cgal-discuss] Compiling the ipelets on OS X 10.7.5 with IPE 7.1.4
  • Date: Fri, 9 Aug 2013 15:15:57 +0200
On Aug 9, 2013, at 13:32 PM, Elena wrote:
> Hello!
> I have a problem compiling CGAL ipelets on OS X 10.7.5. Ipe version is
> 7.1.4.
> CGAL 4.2.0 (installed via Macports, cgal @4.2_0+demos+qt4)
> Demos and examples compile smoothly.
> Now I want to install CGAL ipelets.
> I do
> /*cmake -DIPE_INCLUDE_DIR=/opt/local/include -DIPE_LIBRARY_DIR=/opt/local/
> and get
> /-- Build type: Release
> -- USING CXXFLAGS = '-pipe -Os -arch x86_64 -O3 -DNDEBUG'
> -- USING EXEFLAGS = ' -L/opt/local/lib -Wl,-headerpad_max_install_names
> -arch x86_64
> -Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
> -- Targetting Unix Makefiles
> -- Using /usr/bin/c++ compiler.
> -- DARWIN_VERSION=11
> -- Mac Leopard detected
> -- Requested component: Core
> -- Requested component: MPFR
> -- Requested component: GMP
> -- Found Ipe: /opt/local/include /opt/local/lib/libipe.so
> -- Using IPE version 7 compatibility.
> -- Set Ipelets install dir: /opt/local/lib/ipe/7.1.4/ipelets
> -- Configuring done
> -- Generating done
> -- Build files have been written to:
> /opt/local/share/cgal/demo/CGAL_ipelets/
> Then I do
> /*make install*/
I think you should first do "make" after that invoke "make install"
> and get
> /Scanning dependencies of target CGAL_alpha_shapes
> Linking CXX shared module libCGAL_alpha_shapes.so
> Undefined symbols for architecture x86_64:
> "ipe::Lex::getInt()", referenced from:
> std::pair<int, int> CGAL::Ipelet_base<CGAL::Epick,
> 2>::request_value_from_user<int>(std::string) const in alpha_shapes.cpp.o
> [...] // a lot of similar text here
> ld: symbol(s) not found for architecture x86_64
> clang: error: linker command failed with exit code 1 (use -v to see
> invocation)
> make[2]: *** [libCGAL_alpha_shapes.so] Error 1
> make[1]: *** [CMakeFiles/CGAL_alpha_shapes.dir/all] Error 2
> make: *** [all] Error 2/
> Does anybody have an idea how to deal with that?
> Best regards,
> Elena
> View this message in context:
> http://cgal-discuss.949826.n4.nabble.com/Compiling-the-ipelets-on-OS-X-10-6-8-with-IPE-7-1-4-tp4657910p4657913.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
