cgal-discuss - Re: [cgal-discuss] Combinatorial Maps: create_attribute with more than 1 argument
  • To:
  • Subject: Re: [cgal-discuss] Combinatorial Maps: create_attribute with more than 1 argument
  • Date: Wed, 14 Aug 2013 20:48:34 +0200 (CEST)
Hi Jeremy,
This is not a bug: the attribute can have a constructor with many arguments.
In your example the attribute has only the default constructor with 1
argument, and the Info of the attribute has a constructor with 2 arguments.
Here the correct item class to do what you want:
struct Myitem
template<class CMap>
struct Dart_wrapper
struct Info
Info(int a_, int b_) : a(a_), b(b_) {}
int a, b;
struct Facet_attribute: public
CGAL::Cell_attribute<CMap,Info,CGAL::Tag_true,
Sum_functor, Divide_by_two_functor>
Facet_attribute(int a_, int b_):
Sum_functor,Divide_by_two_functor>(Info(a_,b_))
typedef CGAL::Dart<3, CMap> Dart;
typedef CGAL::cpp11::tuple<void,void,Facet_attribute> Attributes;
Thank you for your feedbaks on combinatorial maps.
Guillaume
