- To:
- Subject: Re: [cgal-discuss] Triangulation refinement with subdomains
- Date: Fri, 23 Aug 2013 14:47:16 +0200
Dear Martin Unfortunately such a functionality does not exist right now in 2D I did not try but it seems to me that the trick you propose to use the 3D mesh generator to solve your problem could work. regards, Mariette Le 21/08/13 18:12, Martin Uhrin a
écrit :
Dear CGAL community, I was wondering if there is functionality in CGAL to do the following: Create a (2d) triangulation from a domain index labelled point set that contains subdomains and refine (smooth) the boundaries between these domains. From what I can can see this is exactly what the 3d mesh generator [1] does but I can't see any equivalent 2d functionality. If this doesn't exist would it be use the 3d generator, by say, replicating my point set at two z values? Many thanks, -Martin [1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_3/Chapter_main.html#Subsection_51.3.1 -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] Triangulation refinement with subdomains, Martin Uhrin, 08/21/2013
- Re: [cgal-discuss] Triangulation refinement with subdomains, Mariette Yvinec, 08/23/2013
