- To:
- Subject: [cgal-discuss] [Arr_Bezier_curve_traits_2] How to get edges' geometry?
- Date: Fri, 23 Aug 2013 09:09:33 -0700 (PDT)
Hi everyone,
I am manipulating arrangements of Bezier curves, using
Arr_Bezier_curve_traits_2.
I need an explicit representation (4 control points) of edges. However, they
are stored as X-monotone curves. Only implicit geometry is available then :
parent curve, plus approximated parameter interval.
I implemented De Casteljau's algorithm in order to "cut" the parent curve at
these parameter values and retreive an approximated, explicit representation
of the edge's geometry.
The problem is : my resulting curves don't start and finish at real
intersection points. I mean, the approximation is clearly visible. For the
following image "input 1" :
<http://cgal-discuss.949826.n4.nabble.com/file/n4657965/input1.png>
I get this vertex and edge set :
<http://cgal-discuss.949826.n4.nabble.com/file/n4657965/output1.png>
For this second input :
<http://cgal-discuss.949826.n4.nabble.com/file/n4657965/input2.png>
<http://cgal-discuss.949826.n4.nabble.com/file/n4657965/output2.png>
Not that curves' endpoints do not match vertices' approximations given by
Point_2::approximate().
I have the following questions:
- What is the precision of approximations on parameter intervals in
x-monotones Bezier subcurves ?
- Is there any other way to go from implicit x-monotone representation to
explicit Curve_2 representation (clamp to rational coordinates, etc)?
- ... Does anyone have an idea for solving this problem?
Thanks in advance!
Hugo Loi
PhD student at Inria - Maverick Team
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Arr-Bezier-curve-traits-2-How-to-get-edges-geometry-tp4657965.html
- [cgal-discuss] [Arr_Bezier_curve_traits_2] How to get edges' geometry?, Tapadi, 08/23/2013
