- To:
- Subject: Re: [cgal-discuss] Re: A valid Polyhedron_3 surface
- Date: Mon, 02 Sep 2013 10:15:05 +0200
Le vendredi 30 août 2013 08:54:59 gupta61 a écrit :
> Thanks Laurent.
> So if I force the to create the polyhedron with points and their
> connectivities such that this property does not hold, I should get an error.
> Right?
Right.
> I am having this issue with one of the surface where the normals are not
> consistent but when I am asking if the Polyhedron_3 is valid, I am getting
> the answer that yes the normals are valid. Another thing is I tried to
> recreate this in a smaller problem (less than 10 facets) but no luck. So is
> it ok if I can send you the file with nodal coordinates and connectivities
> and if you can check if you are getting the same result? If you have any
> preference for the file format, I can dump my data in that particular
> format. Let me know.
The OFF format is the easiest to use with CGAL.
Please do not attach your file to a mail, but post it to a public web service.
Laurent Rineau, PhD
- Re: [cgal-discuss] Re: A valid Polyhedron_3 surface, Laurent Rineau (CGAL/GeometryFactory), 09/02/2013
