[cgal-discuss] Re: CGAL 4.3 Beta 1 Released, Computational Geometry Algorithms Library
- To:
- Subject: [cgal-discuss] Re: CGAL 4.3 Beta 1 Released, Computational Geometry Algorithms Library
- Date: Mon, 2 Sep 2013 05:21:48 -0700 (PDT)
Thank you for the reply.
The reason why I asked the question in this way was, because I expected that
if it was fixed this would be enough to recognize it.
For the nef constructor the problem is similar to:
http://cgal-discuss.949826.n4.nabble.com/Splitting-Nefs-td4656850.html
The input is Valid,closed and regularized, but *not simple*. Mostly if it
fails it does so by an infinite loop, but I got an error just now. I'll try
to get a good example input and start a new thread for this, but I might not
have the time.
For the minkowski Sum: it is also a infinite loop or the same assertion as
in this thread:
http://cgal-discuss.949826.n4.nabble.com/quot-wrong-handle-quot-error-when-running-convex-decomposition-3-td3622877.html
Regards, Sjors
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-4-3-Beta-1-Released-Computational-Geometry-Algorithms-Library-tp4657966p4657991.html
- Re: [cgal-discuss] Re: CGAL 4.3 Beta 1 Released, Computational Geometry Algorithms Library, Sebastien Loriot (GeometryFactory), 09/02/2013
- [cgal-discuss] Re: CGAL 4.3 Beta 1 Released, Computational Geometry Algorithms Library, grivy, 09/02/2013
